Michigan Apollo 3-Blade Prop, Exchangeable Hub / SS, 15.5 dia x 17, RH
We compared price of Michigan Apollo 3-Blade Prop, Exchangeable Hub / SS, 15.5 dia x 17, RH across hundreds of online stores. We found Michigan Apollo 3-Blade Prop, Exchangeable Hub / SS, 15.5 dia x 17, RH in 2 stores with lowest price $284.99 in Overton's. For detailed price comparison of Michigan Apollo 3-Blade Prop, Exchangeable Hub / SS, 15.5 dia x 17, RH check table below.
Merchant | Price | - |
Overton's | [show price] | |
Gander Mountain | [show price] |
Michigan Apollo 3-Blade Prop, Exchangeable Hub / SS, 15.5 dia x 17, RH description from Gander Mountain
High performance stainless steel Apollo propeller with an exchangeable hub system! The Apollo propeller is a proven combination of performance and durability that will wake up your sterndrive or outboard. Michigan Wheels Xchangeable Hub System absorbs impact and stress caused by shifting gears and is designed to spin under significant impact to protect your lower end unit. XHS is also designed to be interchangeable with Mercurys Flo-Torq II hub system, making it a great choice for a replacement or spare prop. Backed by Michigan Wheels limited lifetime warranty. Propeller and Hub Kit sold separately. Michigan Wheel Apollo XHS Propellers must be used with XHS hub system or Mercury Flo-Torq hub system. This Apollo XHS Propeller is the prop housing and blades only. XHS Prop Series A: For use on V6 (4-3/4" Gearcase) Outboard V6/V8 I/O applications Michigan Apollo Part #: 993.
Customer review
Now I bought next two Michigan Apollo 3-Blade Prop, Exchangeable Hub / SS, 15.5 dia x 17, RH! This is the best propellers what I ever Had!
